Help! clutch still slipping
Old May 6, 2001 | 10:14 PM
Crashfirepm53's Avatar
After 1st oil change using mobil oil my clutch started slipping.I saw that some of ya'll use castrol gtx w/ no complaints so i tried that.It still slips.This didn't start until AFTER the oil change.Could there still be enough mobil oil that dinn't drain out to cause a slip.Do i need that $5.00 a quart oil?What does Bomb use from factory?Any help greatly appreciated.
Old May 6, 2001 | 11:36 PM
ScoobyDFW's Avatar
The stock clutch springs may be a bit weak. I would install HD clutch springs. I have experienced the after oil change minor slippage. It seemed to go away after a few cautious rides, being careful not to burn up the clutch.
Old May 7, 2001 | 12:04 AM
NewDSLover's Avatar
Scooby,
Where can I get a set of these springs? Ron Woods? Where?
Old May 7, 2001 | 12:16 AM
DSjockey's Avatar
Both Ron Woods and Team Pani have heavy duty clutch springs, Personaly I don't use auto oil, for the first year I used motorcycle non synthtic oil, these oils are enginered for wet clutchs although I am changing to synthtic oil for this oil change.
Old May 7, 2001 | 09:41 AM
Jimmie's Avatar
hey CRASH mine slipped to when i got stage 1, put the woods clutch springs in and you'll be all set.
Old May 7, 2001 | 10:20 AM
Thanks. anyone have woods or pami #.Cost? are they difficult to install?
Old May 7, 2001 | 05:57 PM
ordered the spings.Ron Woods recommends Redline full synthetic 40wt racing oil.Any comments on this?
Old May 8, 2001 | 09:57 AM
Jimmie's Avatar
redline is expensive as is any synthetic, i'm still using mobil 10w-30, 10w-40.
Old May 8, 2001 | 05:43 PM
eli54's Avatar
Ron Wood Enterprises
(949)645-0393
rotax@mindspring.com
