A few questions
Old Nov 3, 2001 | 09:39 PM
Kodiak01's Avatar
I have a couple questions. here goes:
1.Does anybody know how much the extra lights from the Baja cost?
2.Does anybody know how much the Baja bumper will cost?
3.How well do the Trailtech computers hold up to jumping?
4.Whats some good tires for my DS? I need some tires that will give me good traction and last a while.
5.Which Exhuast system should I get? Graydon or BigGun. I need some more power but need it to be no more than 98db
6.Does anybody sell a CDI w/a rev limiter? I do want a limit, but not as low as 7700rpm
Thanx for any help.
Old Nov 4, 2001 | 04:43 AM
DSjockey's Avatar
The voltage regulator for the Baja has a different connector on it so if you do use it it will require some custom wireing
The kendas are ok if you like powersliding but suck for hooking up and have soft sidewalls that will let the rim hit the ground when landing jumps, hole shots hook up good but are somewhat soft, I think Razor's are harder (longer wearing), they seem to be lasting well on my riding buddy's quad, going to a 22" tire will reduce wheel spin too.
Graydon, and Woods pipes are loud Big Gun with the quiet core might be close to what your looking for but the best bet is to call them if your riding in area with noise restrictions. A few guys have taken there stock end caps and cut the small twin pipes off and welded on a 1 1/2" to 2 " tail pipe piece to it which sounds like what you might need
The Ron Woods and Team-Pami CDI do not have rev limiters try calling Graydon to see if they have a rev limiter on theres althought theres costs $400, $100 more than the others, the Baja has a 200 rpm higher limit with a "softer" limiter on it but I have heard that its connector is not the same as a regular DS
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
