stage 2 jetting
Old Dec 27, 2001 | 06:58 PM
Lakota's Avatar
The reason I removed the air box assembly is due to the snorkle collasping under load and restricting air flow. Knuts said that the direct K&N gives a 3hp increase, thats huge! (on a small motor) Is the acc. pump necessary I know 400EX's have them no there carbs but if it's hard to dial in thats just what I need! All kidding aside if thats what I need I'll get it, but I'd rather get the carb dialed in w/o it. I guess i'll try fatting up the needle.
JSsDS,
When I went to set the jetting, I used the old plugs to get the motor warm and then put new plugs in to get a fresh reading. All my connections are good as far as I can tell.
One other thing, when I took it out, my tach was acting up it read well at low rpm, but after 4g's it went wild so I took it off. My last ride I got water in it. I'm assuming it is water damage, but thats off the subject. (I think)
Old Dec 27, 2001 | 07:36 PM
Hurycne's Avatar
You need to reground your tach to make it work more accurate
Old Dec 27, 2001 | 08:00 PM
JSsDS's Avatar
Lakota,
The malfunction in tach just may be caused by the same thing that is making your engine run crappy. You could have a failing ign. box. try putting your original one back on and see if it still runs bad at full throttle. Also could be the coil.
Old Dec 27, 2001 | 08:10 PM
Lakota's Avatar
I hope it's not the coil or the box! The coils look hard to get to and the CDI was $$$$. [img]i/expressions/face-icon-small-sad.gif[/img]
I still belive it's jetting related, because it was fine before I did the work. I'm thinking on the positive side.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 27, 2001 | 08:30 PM
  #15
ScoobyDFW's Avatar
I assume you checked your gas tank vent line to verify that it is not pinched?
Old Dec 27, 2001 | 10:40 PM
  #16
Lakota's Avatar
Scooby, Checked that, often overthought. I belive that the vent line is on the small side.
Tomorrow I'm going to start working on it again. Do you think it's the CDI or the coil?? I didn't mess with anything that would cause that
Old Dec 27, 2001 | 11:20 PM
  #17
ScoobyDFW's Avatar
Double check both connections to the coils. Anytime you remove those connections, before re-connecting, you should close up the "connector jaws" a little bit to ensure a very tight fit.
How much water did you get on the tach? I have sprayed the back of mine with water before and it survived, although I try to avoid doing that.
Swapping known good components is a good idea to eliminate possibilities. FYI, I rotate my CDI box 180 degrees so that the wiring harness hangs down near the valve cover where I can reach it easily. Now I can swap CDI boxes quicker/easier.
Old Dec 29, 2001 | 04:45 PM
  #18
Lakota's Avatar
That's a good idea. The last ride I took, it was raining and the tach got soaked, so bad It took a week and a half before the condensation dissapeared (please try to overlook my bad spelling)
Do you use electric grease on your connections?
Old Dec 30, 2001 | 02:39 PM
  #19
ScoobyDFW's Avatar
dielectric grease is a good idea for corrosion protection, but most connections are aluminum.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
