HOW MANY PADDLES?
Old Feb 21, 2002 | 12:00 PM
jeffnrivercity's Avatar
I have to agree with Sand45 & JSsDs,I run the 22"x11x10 10 paddle haulers on my 760 & 20x11x9 8 paddle haulers on my baja.The 20" tall haulers are easy to slide around compared to the 22" haulers.If you run the 22" haulers one tooth down on the front might not be enough,probably a 42 or 43 in the rear like Sand45.When I had the stage2 a 15/42 worked well for me with 22"s.
20x10x10 10 paddle haulers will only dig holes,from what I have seen
A 9 or 10 paddle seems to work fine on the 22"
Jeff
Old Feb 21, 2002 | 12:46 PM
hinglbyds's Avatar
Hey CHOP, I have a 2000DS with basically the same set up (RW Stage 1) and stock gears. I just baught the 22-11-10 10 paddle Extreem haulers. They are awsome! The DS turns a little harder than the other strait paddles I've had, but they hook up great and the frone end is very easily pulled up. They are a little hi $$$, but if you think your going to dune more often it worth it. Another excelent choice if the Extreem hauler 20-10-10 9 paddle.
Good luck.
Old Feb 21, 2002 | 10:12 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
HEY CHOP JUST FOR YOUR INFO I RUN 23X12X10 12 PADDLES AND CAN PULL CHINA WALL AT GLAMIS IN 4TH GEAR.GO FIGURE !
Old Feb 22, 2002 | 02:05 AM
TheFasterTheBetter's Avatar
As if life wasn't comfusing enough![img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 22, 2002 | 07:38 AM
  #15
DSjockey's Avatar
As if life wasn't comfusing enough just my thinking too LOL[img]i/expressions/face-icon-small-happy.gif[/img] I have a set of 21-12-10 Sand Skate 1's they are a very good play tire, slide good and climb good, if you run any if the tires from Sand Tires Unlimited you want to run no less than 4 psi, anything less will let the paddle lay back under hard power which can damage the tire casing, airing up will make the paddles standup, jsut the opposit of the skat traks which will lose traction when aired up
Old Feb 23, 2002 | 10:27 AM
  #16
chop's Avatar
THANKS GUYS.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Aug 25, 2015 11:16 PM
BlackHawk
Feb 10, 2001 09:33 PM
TKeeler
Jun 19, 2000 02:20 AM
