Knutz, american star a-arms??
Old Mar 2, 2002 | 12:42 AM
hou650's Avatar
Can anyone tell me why, when you turn the ds hard right or left,
the spindle hits the lower a-arms? Is this normal or is there a fix? Any info would be helpful. Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 2, 2002 | 11:47 PM
hou650's Avatar
Is there anybody with the answer?
Old Mar 3, 2002 | 01:15 AM
BillDS650's Avatar
Same thing happen with my +1 TimmyBoy
Old Mar 7, 2002 | 12:16 AM
suprdavtn's Avatar
I HAVE THE FIX TO YOUR PROBLEM!!! THE NEXT TIME YOU GET WITHEN 8 FEET OF THE TOP OF A 150 FOOT HILL CLIMB DONT LET YOUR RIDE GO BACK DOWN WITHOUT YOU. MESSING UP THE LAST 2 DAYS OF RIDING.
Old Mar 7, 2002 | 12:04 PM
DS650Stage1's Avatar
ok they will barely touch at full click but it will not cause a problem, as you've seen on the videos on my site me and Bailey don't mess around and would not be able to jump like we do without Knutz's arms.
Old Mar 8, 2002 | 12:30 AM
hou650's Avatar
Thanks, ds650stage1 for the info.
Time to air this baby out!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 8, 2002 | 01:18 AM
jeffnrivercity's Avatar
I will be installing my American Star a-arms soon.....Were they easy to set up? Whats the recommended settings?
Jeff
Old Mar 8, 2002 | 08:59 AM
BillDS650's Avatar
Jeff here is a good link on how to make the adjustments on the front end of an ATV. The bad part is that it is on a Raptor [img]i/expressions/face-icon-small-wink.gif[/img].http://www.off-road.com/atv/projects...1/rickystator/
Old Mar 8, 2002 | 12:56 PM
Knutz's Avatar
Clearance on them is extremely close, some touch and some don't. There is no way to tell untill they are installed. Those that do touch, do so in the slightest bit.
So far, I haven't heard of any reported problems from the contact. An early, prototype, version of these arms had more clearance, but didn't prove as strong as this design. The clearance was tightened up for the benifit of strength. It's not what was wanted in the design, but it was found to be the best design.
Old Mar 8, 2002 | 01:01 PM
Jeff add 3 degrees caster and 1 degree camber. Measure your stock arms and go from there, if you need the approximate degree settings let me know.
