DS jetting/mods data
Old Mar 18, 2002 | 05:47 PM
  #21
SoonerDuner's Avatar
Soonerduner:
1. '01 Yeller DS
2. Stock CDI (not for long!)
3. K&N filter & outerwear, stock airbox, lidless
4. Stock carb
5. Kyle's famous end cap
6. Mikuni 180 main jet
7. Stock pilot jet
8. Stock needle 5th position
9. Screw setting - 3 turns out (huh huh, I said screw)
10. No internal mods yet
11. Elev. 1000 - 2000 ft.
12. Stock suspension (not for long!)
13. Stock Gearing
14. Stock Tires (not for long!)
15. Sand tires - Sand Shark paddles
Old Mar 18, 2002 | 06:54 PM
  #22
VEGAS650's Avatar
VEGAS650
00-BLACK
RWR CDI
carb mount K&N
CT exhaust
147.5 main
stock pilot
clip in lowest position
Mixture screw -stock
Pami703 w/RWR cams and Pami clutch springs
elev. 1,000-2,500 ft
susp.-stock
16/41 gears
22" holeshots
STU Paddla Brats and Razorbacks
Old Mar 18, 2002 | 11:01 PM
  #23
DemonDS's Avatar
Ohhh man, Jeff you have to do it!!! Dont send it or send it and post it. That is a list I want to see!!
Old Mar 19, 2002 | 12:46 AM
  #24
DDrecDS's Avatar
Name...........DDrecDS
Quad...........2000DS
Color..........Yellow(plastic)
Frame..........Translucent red over chrome
drilled for wieght.
Battery........Moved under seat.
Stock bracket and bar removed.
Carb...........stock (powdercoated)
Mainjet........180 (mikuni)
Pilot..........Stock
Air/fuel.......3 turns out
Needle.........4th from the top
cdi............Stock
Air filter.....Carb mountK&N Outer wear
Exhaust........Modd end cap
Suspension.....stock (shock protecters)
Gearing........One tooth smaller in front
stock rear
Clutch.........Stock (Pami springs)
Tires..........10 Paddle Haullers
Sand tires on front
Elevation......Sea leval
Riding area....Oregon Dunes
Old Mar 19, 2002 | 11:08 AM
  #25
jeffnrivercity's Avatar
Ok,DemonDS,here it is..............
2000 DS650
Team-Pami from Knutz
Complete racing cylinder head, including two racing cams / stage 2, valve spring set with titanium tops, bronze valve guides, inlet valves die 39mm, exhaust valves dia 34mm, larger valve seats, complete ported and polished, buckets with "shim under", 760 kit:,Forged piston, complete, 12 : 1 compression rate,New cylinder dia 105,5mm,]Boring of the engine case for the new cylinder,Modified oil valve - for higher oil pressure,]A set of stiffer cylinder studs / staybolts,Special crank pin for stroke 87mm,Lightening of the crank,]Lightening of the balance shaft and the gears,Lightening & polishing of the connecting rod Oil reduction jet for cylinderhead, with boring,Port matched intake, HD clutch springs
Ron Wood CDI box
Kehin Dual 39mm carbs with UNI filter/w outerwear
Tach in dash
Frame powder coated yellow
15,16,17 tooth front sprockets 40 & 42 rear
Stainless braided brakes lines front & rear
Gradon Proline Full exaust
Billet gas,oil,& brake reservoir caps,sprocket cover
Graydon steering dampener
Graydon rear skid plate
Pro-tapper CR bend bars
Pro-design kill switch
22x11x10 ten paddle scat-trak haulers in rear
22x7x10 S.T.U razorbacks in front
UPP yellow chain roller
Motion-pro turbo twist throttle
Chromed front bumper,rear grab bar,foot pegs & radiator grill
Black DS seat cover
Battery relocated to front
P.I.A.A.Super white headlamp
L.E.D.Tail light
Dual 39mm carbs W/uni filters and outerwears 165 mains
Holley NOS nitrous kit
Diamond G racing anti vibe steering stem(chrome),
Diamond G Heel guards(polished)
Timmy Boy +4” Extended swing-arm (chrome)
American Star chromoly fully adjustable +1 forward 1 a-arms (chromed)
Full polish of the motor ,radiator and chroming of the side cases
KP chryo treating of the gear box and shifting forks
MRE race cut of transmission w/BMW 2nd & 3rd gears]
Every bolt,nut brake calipers,axle,oil tank,every thing else chrome
Hubs & spindles shaved and chromed
Spyke vent system & catch can
Coming soon, Works shocks
2002 Baja
Pami 12:1 piston & race 1 cams w/springs
Dynojet kit with 195 main w/ Uni filter & outerwear
CT full exhaust
Pami HD clutch springs
22x8x10 razr fronts & 20x11x9 8-paddle haulers rear
Billet sprocket cover
15/40 gears
Ride at 4000” elev
Old Mar 19, 2002 | 04:53 PM
  #26
JSsDS's Avatar
Oh great! I get to follow that? Well this will be quick reading compared to Jeffs
JSsDS
00 DS650
Stock engine
Yoshimura slip-on
Woods CDI
Stock carb
Stock airbox lid removed
w/K&N & outer wares
170 Mik main jet
Stock needle, 4th groove
Air jet ~2-1/2
Stock gearing
Stock tires
Kenda trakkers for sand
Works triple rates w/rezzies
Shock wares
dual lazer lights
Thats it for now
Old Mar 20, 2002 | 09:00 PM
  #27
mintychip's Avatar
Just a quick note, that SN-2550 filter is available at HY-Tech ATV in Redlands, CA for $32.95.
Old Mar 21, 2002 | 12:12 AM
  #28
hinglbyds's Avatar
2000 DS650
RW Stage 1
K&N W/ lid off outerweare
Mikuni 45
155 main @ 70 deg f @ sea level
40 pilot @ 3 turns out on air screw
96 needle clip on 3rd (center)
Pami clutch springs w/ stock disks
Dune tracker's & 22-11-10 extreem 10 paddle haulers
22-11-9 XCT holeshot rear (working on front)
Shockweares
PRM swing arm skid and 6 pack rack
2ea laser lights
Fabricated my own:
Aluminum heel guards
Full aluminum skid
Aluminum shrouds
Aluminum Handlebar light bracket
Oil change fitting (no mess)
Peg extenders
Aluminum battery cover
It isn't the best looking, not real fast, but it runs good.
Old Mar 23, 2002 | 11:04 AM
  #29
buttfungus's Avatar
DS mod info updated..
DS Jetting/Mod info
Old Mar 25, 2002 | 09:37 PM
  #30
buttfungus's Avatar
DS info updated..
Dunerider1 info added.
DS jetting/mod info...
