A-Arm question..
Old Mar 25, 2002 | 05:30 PM
  #21
guardinangel's Avatar
jeff, did you dip all your parts or buy them. are you worried about the engin getting to hot in the sun. don't get me wrong that is a sweet bike!
Old Mar 25, 2002 | 05:42 PM
  #22
jeffnrivercity's Avatar
Thanks JSsDS,I will keep you posted,the 760 will be on the back burner untill after the Terrible's Town 250 race
guardinangel,
I had everthing dipped,except the head,jug and cases which are polished(chroming plays havoc with threads, tolerances, or anything that fits tight.
I was warned that the motor could run a hair warmer,will see what happens.
Jeff
Old Mar 25, 2002 | 07:59 PM
  #23
DemonDS's Avatar
Jeff, correct me if I am wrong, but didn't you have some aftermarket shocks on the 760? I noticed in your pic that those look like stock ones. By the way you are the man, I wish you the best of luck in the race and you really give the DS what it deserves.
Old Mar 25, 2002 | 08:53 PM
  #24
DemonDS,
Your right those are the stock shocks.
I am going to get shocks for the 760,but I was thinking on shorter shocks to lower it down some.But with the DS all apart,different +1 a-arms,+4 swingarm I don't want to chance it.When I get it all back together I will take the proper measurements then order.I figure I will see how low I can go in the back,then match the front.
I did order Works Pro w/piggys 5/8 shaft for the Baja (from Dennis Kirk in stock)Should have them in a couple of days.
Jeff
STLyamwar
Jul 25, 2020 04:44 AM
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
XxS0ccerstarxX
Aug 27, 2015 07:40 AM
DFWSRT8
Aug 20, 2015 09:24 AM
musselmark
Jul 17, 2015 02:40 PM
