ds questions
Old Jul 8, 2002 | 08:41 PM
HEMMI's Avatar
does the filter or outer foam need oiling on the ds, how do you adjust the valve clearances, what tyre pressures do you run in the kendas?
Old Jul 8, 2002 | 09:00 PM
99500scrambler's Avatar
The filter does not need any oil as it is a paper element like that in your car. The stock kenda tires suck at any presure throw them away and get something better. Most people run 3-5 psi.
Old Jul 8, 2002 | 10:19 PM
Hightower's Avatar
Above all - read the manul under the seat. It has most answers in it, and while reading it - order a shop manual from the dealer for $50 - you need it if you're gonna maintain it yourself. Dual overhead cam systems do not have rocker arms and tappet adustments, cams must be removed for replacement of shims.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
