Spudering???
Old Jul 21, 2002 | 08:26 PM
BabyMoose's Avatar
Hey, I need some help here... I think all I need to do is rejet but not sure, my baja keeps spudering and won't go past 3,000 rpms and then it dies. It does this both with the airbox lid on and off. It is completly stock still. Thanks!!!!
Old Jul 21, 2002 | 09:03 PM
Rockey's Avatar
Mine did something very similar to that when the battery died. It would idle fine, but when I tried to revi it, it would sputter. It got worse and worse until i replaced the battery.
Old Jul 21, 2002 | 09:05 PM
glamisds650's Avatar
sounds like it could be the needle clip position, mine was way too rich when i received it. it did the same thing at half throttle, but i was able to go to full throttle with no problem.
Old Jul 21, 2002 | 10:28 PM
ScoobyDFW's Avatar
could be loose coil connection. The connectors need to be very tight.
Old Jul 21, 2002 | 10:45 PM
Hurycne's Avatar
Oh by the way Scooby...could you send my that last dyno chart showing the 100rwhp
Old Jul 22, 2002 | 01:26 AM
DemonDS's Avatar
I went riding yesterday and did a really great climb and the altiude changed significantly. When I got onto a tighter more technical trail it was a bit scary and very frustrating when I would hit a rock or a root and it would start to sputter and then die. Majorecho was with me, actually thanks Major for taking me on that awesome ride!! He thinks it could be a possible float issue and the more I think about it, I think he is right. It could have been a very rich condition from altitude as well, I think it was both. I will let everyone know what I find when I check my float setting.
Old Jul 22, 2002 | 02:40 AM
ThePunisher's Avatar
It's not a carbueration problem. I will have to agree on the battery theory. DSDude's Baja did the same thing, if one of those plates get's jarred in there and touches another one it will short out the battery. His would hold a charge and say 12 volts but one he put a draw on it, it would suck the juice down real fast!
Old Jul 22, 2002 | 04:23 PM
Majorecho's Avatar
Scooby - ya I'd like to see that dyno chart too!
Old Jul 22, 2002 | 07:32 PM
ScoobyDFW's Avatar
I sense some disbelief that I make 100RWHP?
Here is a turbo raptor dyno to get an idea what the possibilities are:
Turbo Raptor Dyno
Old Jul 22, 2002 | 11:52 PM
Majorecho's Avatar
Scooby you must have a sixth sense!
the raptor is making 72 peak HP- have you actually had your bike dynoed or is that a seat of your pants 100hp???
