New coolant?
Old Jul 23, 2002 | 03:02 PM
buttfungus's Avatar
Anyone seen or heard of this product? Waterless coolant Looks very interesting!
Old Jul 23, 2002 | 03:44 PM
MadBaja819's Avatar
Sounds like some good stuff I might have to try it out.
Old Jul 23, 2002 | 06:32 PM
disturbed660's Avatar
i will give it a try
hey, MadBaja819 is ur IM yahoo or what???
Old Jul 23, 2002 | 08:07 PM
AZDUNNER's Avatar
After checking their WEB site it appears that this coolent is and has the same properties as Engine Ice. Costs about the same as well.
Do a search on "Engine Ice".
Old Jul 23, 2002 | 08:52 PM
buttfungus's Avatar
If you look at the properties of the npg, it's a lot thicker at higher temps than 50/50 Ethylene Glycol/water mix. This is the part that I liked-"Motorcycle Installation Guide
We have found that installation of NPG into motorcycles is literally a "Drain & Fill" procedure. Factory flow rates have sufficient volume to run NPG - There are no required modifications to your existing setup and no additional parts are needed to obtain the benefits of an Evans NPG cooled engine.
1. Remove radiator cap.
2. Remove overflow tank.
3. Drain cooling system and dispose of old coolant properly.
4. Flush cooling system thoroughly with water and drain completely.
5. For New systems proceed directly to Step 10. For Old systems in use continue on to Step 6.
6. Replace drain plug, Install radiator flush and fill system with water.
7. Run engine until operating temperature is reached (fans on). Allow system to cool.
8. Remove drain plug and flush system with water as in step 4. Run the engine circulating the water to remove the radiator flush chemical.
9. Allow system to cool Drain completely.
10. Install drain plug.
11. Fill system with EVANS NPG - DO NOT ADD WATER !
12. Run engine until operating temperature is reached (cooling fans on). Allow system to cool.
13. Drain cooling system, replace drain plug.
14. Dispose of contaminated EVANS NPG properly.
15. Fill system with EVANS NPG - DO NOT ADD WATER!
16. Install radiator cap.
17. Clean overflow tank and reinstall. Add EVANS NPG up to Cold Fill line. For the next few times of riding check the level in the overflow tank and add EVANS NPG as required.
Note: Never add water to an NPG Cooled Engine! "
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Kenidah
Sep 7, 2015 07:50 PM
