Tach question
Old Sep 11, 2002 | 06:12 PM
swivel's Avatar
Hoping you DS guys can help. I'm trying to run a HighLifter Tach on my Z400 (I know, I know - but I need to know my RPM's when you guys go sailin buy) Anyway - does the DS use Digital Ignition? If so, do you guys have an existing tach trigger already or is there an adapter that you use to run the factory tach? (assuming it's for CDI) Highlifer is still looking up digital ignition in the dictionary -so they are no help - Autometer (maker of the HighLifter tach) says no way. I can't believe I'm the first shmo to try and add a tach to a Suzuki..but it looks like it ;(
Old Sep 11, 2002 | 10:48 PM
Hightower's Avatar
The DS ignition is CDI.
The tach signal comes directly from the coil wire - its teed right in to it.
The DS tachs are made by Autometer.
Hope this helps.
Old Sep 11, 2002 | 11:05 PM
swivel's Avatar
thanks - that's what I suspected. Nobody knows if a "car" signal adapter will work (convert to 12v square wave). My only option is to buy a $370 aftermarket ignition with tach signal built in...
Old Sep 12, 2002 | 01:22 AM
ScoobyDFW's Avatar
you can use an inductive tach such as: http://www.teamcalamari.com/dox/prod2.html
they might sell a 14,000rpm version instead of 18,000rpm.
it will not respond as fast as a tach triggered from the coil.
there are digital cheap tachs that are inductive, but I prefer analog when monitoring a fast changing signal since digital updates the display very slow.
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Logan Collins
Sep 5, 2015 08:03 PM
