Jetting Qusetion
Old Oct 6, 2002 | 10:26 PM
Sandaholic's Avatar
Im trying to dial in my carb now that I made changes to the exhaust system and air intake. Today I rode it for the first time with the new mods and an elevation of 3300. I noticed I was running a little lean (tip of plug whiteish). I normally ride at sea level, would I be running leaner or richer at sea level then I would at 3000+ feet?
I read some articles saying with gas of today that it is really hard to get a plug reading. I went riding for about 3 hours today and the ceramic part of the plug is still looking like it was when new but surrounding the ceramic it has good dark color.
Old Oct 7, 2002 | 02:17 AM
JMAC650's Avatar
If you go from 3300ft to sea level you will be leaner. Check out buttfungus's website, there is alot of good info on jetting. It's under "DS jetting/mods data".
Old Oct 7, 2002 | 02:43 AM
DuneMe's Avatar
What jet size are you running at 3300' elevation? Needle position? Mikuni Jet or Dynojet jet?
I was running a 175 main Dynojet at 4000' with a K&N in the box, lid removed. I have a Pro-Circuit slip on pipe that probably doesn't have the performance of the Gradon.
If you want to see even more performance improvemet go to the K&N Direct mount (I now run a 185 main Dynojet at 4000' and it pulls much stronger.
You will probably need a new CDI now that you have made these mods since your powerband has moved out to the right (bouncing off the rev limiter.)
Old Oct 7, 2002 | 03:26 AM
Sandaholic's Avatar
I am using dyno jets and I installed them per their instructions. I am running a DJ195, needle on #3. The bike ran great, excellent throttle response and much improved low end.
As far as checking the plug for color, I have heard of a few different ways. One is to ride at full throttle then kill it right away and check the plug. The second way is to just ride it normal for a for an hour or so and then check plug. Any way better then the other? Any truth to that it is real hard to get a good reading on unleaded pump gas?
Old Oct 7, 2002 | 04:07 AM
Ward660R's Avatar
Yes it is true. Here is some good info from Trinity on jetting.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
