PLEASE HELP
Old Oct 21, 2002 | 05:29 PM
DSWOLF's Avatar
Default PLEASE HELP
My buddy just bought a 2001 black ds,is oil was almost white so we changed it and it is still white the coolant is nice an green what do you guys think it could be...
Old Oct 21, 2002 | 05:44 PM
Ward660R's Avatar
Default PLEASE HELP
Did the oil get less milky when you changed it, and is the coollent still full?
Old Oct 21, 2002 | 05:46 PM
RaptorRider660R's Avatar
Default PLEASE HELP
I just had a 250R that the oil was white also, it ended up being a head-gasket.
Nocando
Old Oct 21, 2002 | 06:21 PM
DSWOLF's Avatar
Default PLEASE HELP
Ward i'll check that out and i'll get back to you..
Old Oct 21, 2002 | 10:27 PM
SmoknRaptors's Avatar
Default PLEASE HELP
oil+coolant or water=white/milky oil
Old Oct 21, 2002 | 10:30 PM
Default PLEASE HELP
My oil has looked like that before, b/c I got some water in her, from creek'n. Either that or your leaking antifreeze somewhere.
Old Oct 21, 2002 | 10:43 PM
Bom2000's Avatar
Default PLEASE HELP
Maybe its your waterpump seal. I had the same problem on my dirtbike about a year ago by the time I found out what was wrong it was to late and I had to rebuild the top end again.
Old Oct 21, 2002 | 11:30 PM
buttfungus's Avatar
Default PLEASE HELP
Yep, I would check the waterpump seals as bom2000 suggested.
Water pump seal info...
Old Nov 4, 2002 | 12:11 PM
DSWOLF's Avatar
Default PLEASE HELP
Well guys the rad does not go down but the small white bottle in front of the rad is completely empty and the oil is still milky do you guys think it's the head gasket or the cylinder gasket...
Old Nov 4, 2002 | 12:17 PM
buttfungus's Avatar
Default PLEASE HELP
Did you check/replace the water pump shaft and seals? I would check if you haven't.
