just finished oil change...why is oil milky now??
Old Oct 26, 2002 | 10:01 PM
WIscrambler's Avatar
Default just finished oil change...why is oil milky now??
Hey guys~
I just finished a three week long cleanup of my DS and also did an oil change. I drained the oil about two weeks ago and just filled it up tonight. After running the motor for about a minute, I checked the dipstick and the oil was milky!?? I shined a light down into the oil tank and there are white bubbles on the oil. Could there have been some condensation built up over the two weeks without oil in the engine? What else would cause the oil to become milky? Thanks for any replies.
Old Oct 26, 2002 | 10:18 PM
BillDS650's Avatar
You have water in your oil it could be a blown head gasket or the seals around the water pump. Check your water pump first it is a known problem and easy to fix.
Old Oct 26, 2002 | 10:24 PM
Thanks Bill. I just don't understand why the oil I drained out was completely clean but the new oil became milky after just a minute of running it. Would it seem likely that the water pump seal went out in the time there was no oil in the motor? I think I'm going to try changing the oil first to see if there was just some water somewhere in the lines.
Old Oct 26, 2002 | 11:15 PM
buttfungus's Avatar
I would check the seals first. I wouldn't waste any more new oil until checking it.They are easy to replace. You will need to oder a new water pump shaft,2 -seals at the least. Here's helpful info..DS water-pump info....
Old Oct 27, 2002 | 10:18 AM
DDrecDS's Avatar
mine did the same thing. I changed the oil to a semi- synthetic and my first ride it turned all milky. I changed the water pump seals and shaft and went back to regular oil and it fixed the problem.My seals were shot and the shaft had wear lines on it.The reason I went back to regular oil was the price. I didn't know if it was fixed and I didn't want to waist the good stuff.Good luck
Old Oct 27, 2002 | 03:59 PM
I just drained the coolant and pulled the cover off the water pump. There are grooves on the inside of the cover where the impeller was rubbing it. Would that be a good sign that the seals are gone? I'll be going to the dealership tomorrow and would like to order the parts I will need.
Old Oct 27, 2002 | 05:48 PM
buttfungus's Avatar
Yep, that's the signs! Go ahead and order a new water pump shaft,impeller,2 seals.
Customer Service #1
May 15, 2020 08:46 AM
kbazzy
Sep 26, 2015 11:26 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
