High Output Light Bulbs?
Old Nov 12, 2002 | 11:19 PM
lilnotts's Avatar
Default High Output Light Bulbs?
Theres a bunch out there, which is the brightest? like i've seen super white xenon, super plasma, and some that have blue tint or gold tint, which is the best?
Old Nov 12, 2002 | 11:24 PM
MadBaja819's Avatar
I run the 55/100w blue tint xenon and you would think its noon when you turn those baby's on. I have also been shopping arund for a orange tint.
Old Nov 12, 2002 | 11:28 PM
Sandaholic's Avatar
I also like the super white xenon bulbs. I use a 55/100w main bulb and 2- 55w side lights
Old Nov 13, 2002 | 10:42 AM
duneyfz's Avatar
Where do you guys buy your bulbs?
Old Nov 13, 2002 | 07:15 PM
lilnotts's Avatar
sandaholic, do u you find that it uses too much power or creates too much heat? i was also thinkin about gettin the baja lights for christmas, but i thought i'd try the high wattage bulb first, i think i'll go with the 55/100watt blue tint, i can get it much easier than the superwhite, and duney you can get them at Dennis Kirk, Kimpex etc.
Old Nov 13, 2002 | 09:27 PM
Sandaholic's Avatar
So far I have had no problems with the high output lights. I am cautious though, I only use the low beams when I am just putting around, If you leave the high beams on I would think the heat build up and over draw on the power system would not be a good thing. When you are crusing at a good speed the air flow over the headlight aids in the heat dispersion, also the stator will be putting out max watts at over 3000rpm + or around that.
Old Nov 13, 2002 | 09:28 PM
Sandaholic's Avatar
I got my bulbs from JC whitney online
Old Nov 13, 2002 | 09:36 PM
lilnotts's Avatar
i think i'm just goin to go with the high watt bulb in the main so that way even if i'm on high it'd only b 170 on high
Old Nov 14, 2002 | 11:50 PM
MudStud's Avatar
I just went to the local Napa and got the 55/100 I think it was an H4? The main light is made of glass, no melting problems for me.
Old Nov 15, 2002 | 12:57 PM
Hightower's Avatar
the purpose of the tinting is to keep from blinding oncomers as bad - the blue xenon and gold tints don't glare in the eyes near as much as the normal bright whites.
I like the 55/100 so I can run the factory watt low beam around camp, then hit 100w high beam out in the dunes.
JohnnySplat
Aug 6, 2015 12:07 PM
Schneider
Jul 24, 2015 05:05 PM
ltrmc02
Jul 22, 2015 04:50 AM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
Chocobamofo
Jul 10, 2015 07:46 PM
