CDI??????
Old Dec 30, 2002 | 10:45 AM
MadBaja819's Avatar
Default CDI??????
Ok, I saw a read a post on another site about switching the CDI's and I believe I've gotten it squared away. All I need is the adaptor off a standard DS am I right?
Old Dec 30, 2002 | 09:16 PM
lilnotts's Avatar
Default CDI??????
blackhawk, thanx for the info, i didn't realize that it made more everywhere, i thought it just continued to make power past 6800? where the stock stops,
Old Dec 30, 2002 | 11:02 PM
lilnotts's Avatar
Default CDI??????
marky, i understand that, i just never saw a dyno of it or n e thing so i was just guessing really, but blackhawk already cleared that up for me, but thanx n e ways
Old Dec 30, 2002 | 11:05 PM
crashnburn's Avatar
Default CDI??????
I found this somewhere (I can't remember where). I figure I'de need it when I get my CDI, which I haven't got yet [img]i/expressions/face-icon-small-frown.gif[/img]
RW-cdi...to...Baja-wiring
red......to...red/violet
white....to...black/yellow
orange...to...white/green
black....to...black
blue.....to...black
green.........not used
Old Dec 31, 2002 | 12:16 AM
  #15
JSsDS's Avatar
Default CDI??????
Can't you just take the plug housing off your stock CDI and put it on your RWR CDI?
The only other alternative is to buy another brand of weather pac connector and match the wires.
Also, Make sure you write down the wires color match of your stock CDI/harness just in case you have to use it again.
Old Dec 31, 2002 | 12:22 AM
  #16
jeffnrivercity's Avatar
Default CDI??????
The stock connector on the Baja CDI is part of the plastic housing...It has no pigtail
Old Dec 31, 2002 | 10:29 AM
  #17
MadBaja819's Avatar
Default CDI??????
Jeff, sorry for so many questions, but electrical was not my strong point and I just wanna get everything right. So the RW CDI has a pigtail on it with a plug on it. Now my question is do you have to get a plug the will except the RW side on side and the BAJA on the other, or is the plug on the RW removale? Thanks, so much for all the help.
Old Dec 31, 2002 | 11:14 AM
  #18
Default CDI??????
Huh?
All the connectors are remoable except the Baja CDI connector
I would get a connector that accepts the RW CDI and install it on the Baja harness
Old Dec 31, 2002 | 11:52 AM
  #19
BIGBAJA's Avatar
Default CDI??????
I went to Radio Shack and got 2 6-pin plugs, 1-male and 1-female. Just cut off the stock plugs on the RWR cdi and the Baja, and then just solder the new plugs on the wire ends in the correct order.
Old Dec 31, 2002 | 11:53 AM
  #20
MadBaja819's Avatar
Default CDI??????
Ok, thanks, I gotcha I'm squared away on everything now, thanks for all the help.
