Compression ratio vs. fuel requirements
I need to know what compression ratio is the cut-off for 94 octane pump fuel? ie. Can I run a 12:1 piston with 94 octane???
Fuel requirements has more to do with cylinder compression ratio than a given ratio. 170lbs psi 87-89 octane-----------------------------------------------stock 250R new rebuild
175-185 psi 89-91
190-200 psi 92-94
205-210 psi 100
215-220 psi 105-108
225-230 psi 110-114 octane------------------------------------------ 250R 14 to 1 ratio with 18cc dome head
My 400 polaris 2 stroke is 160 psi
175-185 psi 89-91
190-200 psi 92-94
205-210 psi 100
215-220 psi 105-108
i too was wondering how high i could go on the compression ratio and still run pump gas.also,how high can you go and still have great reliability? also,who are the best hop up companies for the DS pistons and cams? THANKS.
Hankey Pankey
Jul 31, 2015 05:50 PM
190, 220, 225, 97, compared, compression, fuel, head, octane, psi, ratio, requirement, requirements, stroke, watercraft
