Pro Design Super Cooler
Old Jan 4, 2003 | 02:12 AM
lilnotts's Avatar
Default Pro Design Super Cooler
It doesn't look to hard to make one of these, has anyone every tried? If anyone has one could they give me measurements they would be very helpful? I have access to brass, steel and aluminum, would aluminum be best to make it with like the pro design one? Is there any thing i should really know when making one of these? I'll also be making a bar riser before i start this so i'll let you all know how it goes
Old Jan 4, 2003 | 04:12 PM
brad650's Avatar
in shop class i got access to a lathe, so i think i am gonna make myself a aluminum one, im still thinking if i want to but i dont really know what coolent line i should put it on? and i dont evan know if they do anything?
Old Jan 4, 2003 | 04:53 PM
BajaDS650's Avatar
Sat January 04, 2003 12:51 PM (NEW!)
No signature allowed
^What is that all about??
Old Jan 4, 2003 | 07:21 PM
AdamsBadDS650's Avatar
lilnotts, I actually have a new one sitting in my garage. I will just send it to you, and when you are done, send it back. I am in no hurry to put it on. Send me an e-mail with your address, and stuff, and I will send it. TxDS650rider@aol.com
Old Jan 4, 2003 | 08:19 PM
SANDMAN430's Avatar
i just got mine a few days ago and it is sitting here on the desk it is 2 3/8 long, it seems to be milled out of 1 1/8 stock, the cooling fins are 13/16 with 1/16 in between the pipe itself is milled to 11/16 with 3/4 rips on the end to catch the hose ends.the inner dia. appears to be 1/2"
Old Jan 4, 2003 | 09:47 PM
66oDisturbed's Avatar
WTF..no sig allowed .... i get to have one... and u don't????
something isn't right here....i can get away w/ murder and u guys can't have a sig....O K ???
Old Jan 4, 2003 | 10:39 PM
crashnburn's Avatar
I saw that someone makes a cooler that is a little larger and dissipates heat better. Its pretty extreme[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 5, 2003 | 04:25 AM
BlackHawk's Avatar
That cooler is the hot ticket, out on dunes if your looking for performance.
Old Jan 5, 2003 | 08:53 AM
Hightower's Avatar
Supercoolers help most on the return line - the short top one - and should be made of aluminum because it dissipates heat the best and fastest of the materials mentioned. If your making them, make two - one for both lines, every little bit helps.
Old Jan 5, 2003 | 06:19 PM
lilnotts's Avatar
i was thinking about making a really big one to put on the intake like coming from the bottom of the rad to the water, so it would come out of the rad got to a right angle fitting, threw my super cooler, then threw another right angle fitting going straight to the water pump, the id of mine wil be 3/4" so it will not slow down the flow, i will also have brackets so it can be bolted to the frame so it will not bounce around, wat do u think?
