oil lecking
Old Jan 8, 2003 | 01:04 AM
cOoLdevil's Avatar
Default oil lecking
hi guys i have a problem when i came back from long day ride i leave me atv on the trailer and it leanse the atv to the front and after some days you see oil on the flour and i tride to find where it came from i didn't get it but when i leave it on the graund thear is no oil can any one give me any ideas . thanks[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 8, 2003 | 01:07 AM
kehale's Avatar
Default oil lecking
I think you should wash it really good. You should be able to find the leck on your next ride.
Also, check the flour where it is dripping and try to chase the leak down. It could be a loose return hose on the left side (oil hose), or simply a leaking oil drain plug (don't overtighten)
-T
Old Jan 8, 2003 | 02:21 AM
QUADMAN650's Avatar
Default oil lecking
ALRIGHT FIRST YOU GUYS NEED TO LEARN HOW TO SPELL
CHECK YOU VENT TUBE COMING OUT OF THE CRANK CASE THATS PROBALY WHERE THE OIL IS COMING FROM IF IT IS DON'T WORRY ABOUT IT AS LONG AS ITS NOT ALOT OF OIL MINE DOES IT ALL THE TIME
