batt relocate
Old Feb 26, 2003 | 12:26 AM
quadloco1's Avatar
Default batt relocate
Hey kmdunner how do you make a link like that?
Erik
Old Feb 26, 2003 | 11:34 AM
KMDuner's Avatar
Copy your link by highlighting it and holding down your CTRL key and tap the C key. This will copy what ever you have highlighted. Then when you reply to a message click the HTTP button on the top left, first it will ask you to input the link, well since you already have it copied hold down your CTRL key and tap the V key, this will paste the link. Click ok. Then it will ask you to name the link, this is optional and you can type in whatever you want.
That's it, make sense?
Old Mar 12, 2003 | 01:12 AM
BOOKEND's Avatar
HEY WHATS UP WHAT I DID IS REMOVED BACK FENDER & WITH A CUTTING DISK ON A 41/2" GRINDER & CUT OUT OLD BATTERY HOLDER AND GOT A COUPLE OF L BRACKETS AT LOWES HARDWARE JUST MOUNT THE L BRACKETS WHRE AIR BOX WAS MOUNTED ON SIDE FRAME RAILS AND BOLT HOLES ON OLD BATTERY HOLDER LINE UP PERFECT TO L BRACKETS ANY QUESTIONS ILL BE HERE I CHECK EVERY DAY NOW
GOOD LUCK
CARLOS
(BOOKEND)
Old Mar 12, 2003 | 04:31 AM
Fourwheelphreek's Avatar
any pics?
Old Mar 12, 2003 | 02:15 PM
  #15
brad650's Avatar
WHERE CAN YOU BUY RACE WHEELS WITH THE RINGS FROM? HOW MUCH DO YOU THEY COST? ANYBODY GOT ANY THEY WANNA SELL, I WANT SOME BAD!!![img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 12, 2003 | 03:06 PM
  #16
contact omf in riverside california brad, the cost is $40 a ring
Old Mar 12, 2003 | 04:26 PM
  #17
brad650's Avatar
so do you bring them to a local weld shop? or do you send your wheels out and have them weld the ring on for 40$ bucks a rim?
Old Mar 12, 2003 | 05:55 PM
  #18
dsr's Avatar
dsr
brad i pm'ed you about a set of ring supported wheels and tires i have for sale.
Old Mar 12, 2003 | 05:56 PM
  #19
typically you would send them your wheels and they would weld them, but if you know of a local shop with a tig welder, you could order just the rims
Old Mar 12, 2003 | 11:02 PM
  #20
BOOKEND's Avatar
hey brad650 you can go to a scrap yard they will have alluminm squares the squares will be 11" that way you can cut fronts at 10x1/2 & the rear will be 9x1/2 i cut them out with a grinder with a cutting disc &a local shop in the ghetto part of phoenix for $50 dollars small shops cheaper & well the with of the ring is up to you me rear are 1" width & front are 1" also they look great [img]i/expressions/face-icon-small-smile.gif[/img]
