ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   CAN-AM (BRP) (https://atvconnection.com/forums/can-am-brp/)
-   -   Difference in DS650's between model years? (https://atvconnection.com/forums/can-am-brp/96315-difference-ds650s-between-model-years.html)
taitgt2002 Apr 16, 2003 11:02 PM
Since I'm looking into getting a DS, I figured I would see if any of the years have quirks or problems, or if there were improvements in some years worth looking at. 2000's obviously are the cheapest, but were there any problems with them? Thanks.
SANDMAN430 Apr 16, 2003 11:18 PM
00- has a smaller oil filter, and the oil doesn't bleed itself or something along those lines.
the arms are a topic for some people, the fan isn't rubber mounted, the chain roller sucked $23 fix, the kenda tires were sh!t, as in slick as.
01- oil filter larger, same a-arms , fan same, oil bleed thing changed, other than that same i think.
02 and on they changed tires , and a-arms and chain roller basically all the little things.
all the problems are little things the fan can be a issue but a lot of us don't run one anymore.
taitgt2002 Apr 16, 2003 11:22 PM
I'm assuming it's a screw on filter... Is there a bigger filter that fits the same threads? So really there is nothing major, spend a night in the garage and fix most of the issues with the '00 year right?
How reliable are the quads? Transmission and the motor run long and hard?
PUSHINTHELIMIT Apr 16, 2003 11:24 PM
Am I the only one with a 2000 ds650 with the fan and chain roller that it came with from the factory???[img]i/expressions/face-icon-small-smile.gif[/img]
brad650 Apr 16, 2003 11:51 PM
the ds motor and tranny are awsome, but yes my chain roller and fan both SH*T the bed haha, so i put in a skate board wheel with good berings and the right size bolt, and it works awsome. next time the fan goes im just gonna leave it out and run engine ice [img]i/expressions/face-icon-small-smile.gif[/img]
taitgt2002 Apr 16, 2003 11:55 PM
What oil problems is everyone referring to exactly? Have you experienced these problems?
brad650 Apr 16, 2003 11:57 PM
ive changed my oil and oil filter lots of times, and there is no problem at all [img]i/expressions/face-icon-small-smile.gif[/img] i think the yellow ds are the best looking ds. they should make them in yellow again. [img]i/expressions/face-icon-small-smile.gif[/img]
taitgt2002 Apr 17, 2003 12:07 AM
OK but by 'bleeding' he was trying to say that when you drop the oil, there is still a fair amount of old oil left which is hard to get out, or what? I guess I'm confused by what he meant by 'bleeding'. Also, does the bike run OK without the aid of the fan, or does it get too hot at times?
SANDMAN430 Apr 17, 2003 12:29 AM
no it has something to do if you flip your quad upside down that the oil pump loses prime or something, i guess the oil light comes on to let you know, i'm not the best at the oil on the 00 mine is the 01 and not a issue.
taitgt2002 Apr 17, 2003 12:32 AM
Hmmm... Well the poor thing will probably end upside down every once in awhile but I'm sure someone knows more about it.
© 2026 MH Sub I, LLC dba Internet Brands
