ds650 kickstarter
Old Apr 19, 2003 | 08:25 PM
CanadianBaja's Avatar
Default ds650 kickstarter
Is there any way you can add a kick starter to a DS650? Any way at all...
it sure could use one just in case...
thanks
Old Apr 20, 2003 | 01:50 PM
bombrider's Avatar
Why would you wunna do that?
Old Apr 20, 2003 | 01:55 PM
Bom2000's Avatar
I have tought about it just in case all electrics go out like if you blew a fuse or your rectifier decided to die out and your battery was dead it would be nice to have a back up kick start to get you home.
Old Apr 20, 2003 | 04:12 PM
brad650's Avatar
DS's do have a backup start... put it in 2nd gear, pick up the back end than run and drop the back end down! works good for me [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 20, 2003 | 04:32 PM
TyreSpinner's Avatar
yes,
we call that push-starting. Try pulling in the clutch on 1st, push it as fast as you can then release the clutch...should start...Haven't tried it on a DS but usually works.
Old Apr 20, 2003 | 04:54 PM
CrazyWhiteDude's Avatar
but i thought that somebody said that the ds won't run with a dead battery.
Old Apr 20, 2003 | 06:21 PM
dunno..but a kickstarter wouldn't help worth poo then would it? Kickstart is just another way of turning the engine, just like push-starting or recoil...all the same.
Old Apr 20, 2003 | 06:26 PM
PUSHINTHELIMIT's Avatar
A DS650 wont run with a dead battery. Believe me, I had to walk accros a lake because of this, and got stranded in the middle of the night.[img]i/expressions/face-icon-small-frown.gif[/img]
Old Apr 20, 2003 | 07:00 PM
Back to my point, a kickstarter wouldn't help anything.
Correct??
Old Apr 20, 2003 | 07:39 PM
bigben's Avatar
I was thinking that a kickstarter wouldn't be very helpful because it would be INCREDIBLY hard to kick over.
Based on experience with a dead Raptor, you're not going to push start one either. 650+ cc's won't turn over in first gear. Tow starting with another quad and using a higher gear is the trick.
I don't know if a DS will run with a dead battery or not. I'll take PUSHIN's word on that one.
