Split cases???
Old May 8, 2003 | 12:43 AM
Hurycne's Avatar
Default Split cases???
Who here has split the cases? Anything special to watch for???
Old May 8, 2003 | 12:48 AM
Majorecho's Avatar
be sure that you have the magnito side facing down when you open it or everything will fall apart. ( build an appropriate support under the case to support it) Also remember to remove the plastic gear on the clutch side so you can actually saparate the cases with out damaging them. [img]i/expressions/face-icon-small-happy.gif[/img]
also take note of the order the washer and spacers are in around the starter gears- the manual doesn't have a good pic and if you misplace them the gears will bind up.
Old May 8, 2003 | 12:58 AM
Hurycne's Avatar
Thanks...anything else??
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
WilliamBos
Sep 22, 2015 04:07 PM
1ArmBandit
Sep 8, 2015 08:59 PM
