please help
Old Nov 20, 2006 | 04:03 PM
dannyboy06inthehouse's Avatar
Default please help
i got a 110 falcon and it would not start so i pulled the spark plug out to see if it was getting any fire and it was not, so i put a new cdi on it and a new coil and it is still not getting any fire do you think it could be the magneto if the magneto goes out would that cause the lights not to work also
Old Nov 20, 2006 | 07:10 PM
2manytoys's Avatar
Default please help
If the magneto goes out it will not generate any power to run anything. The more common problems are the master switch, fuse or something with the wiring. It is rare that the magneto goes but it is likely if you ride in alot of water and mud. Check all your connections, fuses and switches.
Old Nov 21, 2006 | 06:20 PM
Default please help
hey i put that magneto piece on and it still didn't fire i checked the connection's everything look good my two front lights don't come on maybe it is a switch the fuse by the battery is ok but i don't no what to do
Old Nov 21, 2006 | 11:16 PM
2manytoys's Avatar
Default please help
The lights dont come on unless its running.
