How do I disconnect the alarm/remote start on 100 Utility
I have been having problems with the batt staying charged and was reading other posts about the sunls which also have this alarm/remote start causing battery drain even when the key is off. I have the Utility 100 from Raceway and was wondering if anyone can tell me how to disconnect these added features. I read where some you just unplug the alarm/remote, but some you have to bypass by rewiring.
tks
tks
Ok I went looking around on the Utility 100 atv and found a red fuse that is plugged into a white plastic connector that is underneath the front end of the atv right beneath the plastic in between the frame. I took the fuse out and it has disabled the alarm/remote key start. It will not start with the remote nor will it sound off the alarm when pressing the alarm on the remote, however the atv still does start and turn off by turning on and off the key. I also noticed that with the key off I inserted the fuse to make sure that is was disabling it and when you insert the fuse you get a tick sound from the speaker, therefore even if the key is off this is using battery power. So I will try to see if this works to avoid battery drain. I hope this helps others with the similar problem.
alarm, alarms, atv, chinese, chinesse, disable, disconect, disconnect, disconnected, disconnecting, fourwheeler, quad, remote, start, starter, wont
