Carb/gas leak issue
Old Mar 20, 2008 | 04:23 PM
Marksvilleman10's Avatar
Default Carb/gas leak issue
Hello All,
For those of you who helped me with my clutch issues - Thanks again. I did get it fixed. I needed a new clutch. I have it on now and seems to be working good. No creeping anymore. However, I now have another problem that I realized while digging into this clutch. When the gas is "on" and the engine is turned off, the gas will leak out of the bottom of the carb. If I turn the switch to "off" no gas leak. Any idea why this is happening?
FYI...Most of you probably know this, but I was told by the mechanic who helped me with my clutch that if you are going less than 20mph, you should be in low at all times. High is for anything over 20mph. I always thought low was just for pulling, plowing, etc. hmmm
2001 sportsman 500 h.o. duse
Old Mar 20, 2008 | 10:42 PM
QWODER's Avatar
sounds like the float is sticking.Tap the bowl on the bottom of the carb and see if this stops the gas from leaking.
Old Mar 20, 2008 | 10:52 PM
outofline's Avatar
Some times lifting the rear of the quad and shaking it or dropping it could unstick it also. Or if these things do not do it then your float needs to be adjusted!
Old Mar 25, 2008 | 09:10 PM
Jetmoto_Canada's Avatar
If it has not been historically leaking then I would try and drain the bowl. There may be a bit of crud stuck under the needle. To do this try the following:
1. Turn off fuel at the fuel switch
2. Open the bowl drain and allow all the fuel to drain out. The bowl drain is that brass screw located at the bottom of the carb directly above the drain hose.
3. once all the fuel has drained out open the fuel shut off and allow fuel to flow for 5 - 10 seconds.
4. Shut the bowl drain screw.
Then wait for a couple a minutes to see if the fuel continues to leak. If it does then I would try and adjust the float as outofline mentioned
Good Luck!
Old Mar 25, 2008 | 11:29 PM
Thanks guys. I will take a look and try the things mentioned.
Cummins Driver
Sep 11, 2019 01:22 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Jul 29, 2015 10:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
