help with rear axle leak
Need some help with my son's 150cc coolster atv if anyone here is familiar with that brand. I would assume that there would not be all that much difference in it and most of the chinese made atv's. I keep adding 90 wt oil to the rear end and oil keeps slowly leaking out down the left side (looking at from the rear) of the axle and coming out at the inside and outside of wheel. I took the wheel off and there is a hollow cylinder about 8 or 10 inches long that slides over the axle and pushes into a little ring and this pushes into the bearing. I assume there should be some sort of seal there but without an illustration or photo i don't know. I took the right wheel off to see how it is put together but i cannot get the cylinder off and i don't want to force it off and mess it up and get it to leaking. If anyone here has any idea or could share an illustration or point me to a place where there is a break down on the parts i would greatly appreciate it. ....thanks
it does look like that...thanks
so does anyone know how big of a job it is and what exactly is involved in stopping this oil leak.....thanks
Did your quad come with a parts book of some sort?? That would show a blow up of the parts in the rear axle. If you had this you could see what all is involved. From the picture it doesn't look too bad.
Give this a try.
PartsProUSA Chinese Scooter ATV Parts & Accessories I checked it out real quick, didnt spent much time there. However they did have diagrams of assembly, also advertise over 30,000 parts for chinese bikes. Good Luck!! |
Originally Posted by HawkeyeRider
(Post 2789882)
Give this a try.
PartsProUSA Chinese Scooter ATV Parts & Accessories I checked it out real quick, didnt spent much time there. However they did have diagrams of assembly, also advertise over 30,000 parts for chinese bikes. Good Luck!! PartsProUSA Scooter & ATV Parts | REAR AXLE In this one you can see the axle well, looks like on the right side there is a seal, is it the same on the left? IF so maybe you need a new seal. I'm sure if you take the seal to a Bearing/seal time place they could match you one up. |
hey thanks for all the replies guys and the link. Ive been trying to find some site like this but had not been able to ....thanks again
Originally Posted by oren213
(Post 2790464)
scematics to look over. Unfortunately this site does not have quads with that axle anymore. |
Here is another place that might have parts if u need them.
Coolster ATVs Parts |
