SMC Urban 50...Keihin PE20 jetting
Old Mar 31, 2015 | 09:17 AM
jdmisme's Avatar
Here in Japan, it's simply called the UR50. The different names in different countries made it really hard to track down a parts list.
Old Mar 31, 2015 | 09:20 AM
jdmisme's Avatar
Originally Posted by LT80
...I'm leaning toward that pipe being aftermarket but I can be wrong. It'll prolly be fine.
Wow...I never noticed the exhaust in the parts list...it's so different than the one this has. I see your point with thinking it's aftermarket. I just never imagined an aftermarket exhaust getting to this point (rust/decay).
Old Mar 31, 2015 | 03:56 PM
supermanotorious's Avatar
Winchmaster 5000
just showing you where my engine ID is. and by the way these look exactly like the yamaha raptor which it very well could've been reverse engineered from
Attached Thumbnails SMC Urban 50...Keihin PE20 jetting-025.jpg   SMC Urban 50...Keihin PE20 jetting-026.jpg
Old Apr 10, 2015 | 05:16 AM
jdmisme's Avatar
Just wanted to give an update. I found a local shop that sells a myriad of parts for bikes and scooters. Was able to get a #100 and #105 main jet and a #45 pilot jet, so those are ready to go.
Last week I tore the buggy down. I spent last weekend making a sandblasting cabinet in my open basement and everyday except for one this week sandblasting the frame, upper/lower arms, almost every metal part that could be removed from the frame and the clutch/variator housing.
This is it, in bits and pieces:
As you can see, the frame was in nasty condition:
Clutch/variator housing prior to blasting:
This is what it looks like, now...ready for reassembly:
And the housing:
Clutch and variator installed:
It's not perfect, but I'm satisfied. Again, considering I started with this:
I'll start putting the whole thing back together tomorrow if it's not raining.
Old Apr 10, 2015 | 11:01 AM
  #15
MPDano's Avatar
Nice work man. Showing a lot of love for this little quad. I too am surprised that motor didn't just blow up without oil in the gas. I've heard lot's of horror stories of this happening. I too disabled the oil injection and now use pre-mix in my sons quad. Except I put a sticker right by the gas cap to put only pre-mix in. Keep up the good work.
Old Apr 10, 2015 | 07:53 PM
  #16
jdmisme's Avatar
Thanks. I just woke up...my son and I are about to go outside and start putting it together. You brought up one of my next questions...pre-mix. I've been seeing a lot of 32:1. What would you recommend?
Old Apr 10, 2015 | 08:41 PM
  #17
MPDano's Avatar
32:1 is a good mixture. Plenty of oil. That's what I use on all my quads. My son and I have KTM Dirtbikes and they run lean at 40:1
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
