What happened in the rain?
Left my 06 Linhai 300 out in the rain for a few days to get "rinsed off" and it wouldn't start. Ended up replacing the battery and got it started for a few seconds and then die with and without throttling. Sprayed some carb cleaner and then starter fluid in and was finally able to get it running up to the garage where I let it idle for almost 10 minutes. Thought all was well but it still runs real rough, pops, and stalls out. Almost feels carb/fuel related but it had been running well with 0 issues up to this point. Any ideas or should I just let it dry out for a few days? thanks
Probably got some water in the gas or some of the electronics got wet. 8 would start by draining the tank and carb of all the fuel and put in fresh.
Originally Posted by wannabe32
(Post 3291970)
I try not to leave my ATV's directly in the rain. Harbor Freight has inexpensive tarps to cover your ATV if it needs to. |
Spray some water proofing ignition spray on every wire and terminal you can see.
http://www.kenzandleslie.com/Portals...res_289418.jpg |
Originally Posted by TLC
(Post 3292499)
Just left it to dry in my garage but it still is acting up a lot. Need to give it lots of gas to get it going and really rev it in neutral before it will not stall. Even then the engine really hesitates sometimes when attempting to accelerate and will sometimes sputter and backfire before totally bogging down. Sometimes it will recover and sometimes it won't and stalls out. Should I keep trying to get fuel with injector cleaner through or do I need to get to the carb? Where is it and how hard is it to clean out? Thanks!
Yes, you need to drain the carb and gas tank, then put in fresh gas. Usually they will have a drain at the bottom of the float bowl, but you may need to remove the bowl. I had one of these issues and didn't completely drain the bowl. It took a lot longer to clear the bad gas than I would have thought.
Hopefully that is your issue because at least it is a cheap fix. |
