jaquar 500 starting questions
Old Jan 30, 2017 | 03:55 PM
carkivey3's Avatar
Default jaquar 500 starting questions
i picked up this 2007 kazuma jaquar 500 at an auction. hooked up battery and nothing. traced hot wire from battery to ignition sw on on handlebars. power there but nothing on yellow or black wires when i turn key so i know ignition sw is bad. i jumperd to yellow wire and speedo box lit up. since there is a start button on left handlebar what are the 3 positions on this switch for? i also see a key on on right side fender. looked under there and there are no wires on it like they may have been removed on purpose. what is this key for? assuming i can find a replacement ignition switch what conditions do i need to start this. i assume neutral or clutch in and footbrake depressed, anything else to look for. if anyone else has replaced there ignition switch can you please give me ordering info. thanks for any help
Old Jan 30, 2017 | 06:23 PM
carkivey3's Avatar
Default owners manual
found an owners manual. key on fender is for handelbar lock. it shows ignition switch but only mentions 2 positions. still dont understand the three positions. a
