TaoTao 110 4 stroke mixing with 2 stroke
Hello looking for a little advice
i have a 110cc 4 stroke chinese quad which i have recently purchased
upon purchase i noticed that the gas / petrol was a pink color so seeked advcei and was told they had mixed oil with petrol
So i have changed the full petrol tank and put fresh petrol in it aswell as this i topped up the oil in the oil chamber
the atv seems to be sticking while trying to start and quite alot of white smoke comes from the exhaust. when its running it does run ok apart from the issue with starting / sticking and the white smoke from the exhaust
also spark plug is black
any advice for this issue?
thanks for reading
thanks for reading
I am so confused. Is the machine a 2 or 4 stroke? What oil chamber did you top off? By top off do you mean "filled chuck full" or "put only the appropriate amount as indicated by the dipstick"
the machine had marked fuel in it. it's used in marine or farm applications nothing wrong with it just a little cheaper for the farmers. as stated above make sure you only topped up the fuel to the mark on the dipstick or 1/2 way up the sight glass. Change your spark plug and that should clear up the rest of the issues. That may also clear up the smoking issue.
thanks for your reply
