2004 Baja commander 250cc.
Old Mar 22, 2018 | 07:53 PM
JeremyBoulay's Avatar
Default 2004 Baja commander 250cc.
Hello Everyone,
I currently own two quads. One is a 2004 Baja Commander 250cc 4 stroke water cooled automatic but transmission case is gone and machine isnt running yet. See pics but rest of machine is clean except for some cut wires.
the second is a polaris trailblazer 250cc 2 stroke air cooled also automatic that runs and drives but needs a lot of work on the frame and plastics. I was wondering if I can use the transmission on this one and will bolt to the Baja. Also if that can't happen, can ayleast do a motor swap. Will the trailblazer motor work on the Baja frame?
Thanks for the help
Needs ball joints, a pull start, frame has bends, tires are junk, plastics crack, and missing some pieces. Rather use it for parts.
Baja 250
Very clean, good tires, tight suspension, no cracks on the plastics. Just needs a transmission and engine work.
Jeremy
JeremyBoulay
Mar 22, 2018 07:56 PM
killerklown
1) Engine problems..
Nov 5, 2012 10:37 AM
two4ruff
Dec 5, 2007 08:01 AM
AZtransplant
Apr 27, 2007 04:57 PM
MotoXtreme
Jan 18, 2004 07:00 PM
