how to adjust rider weight on works shocks?
Old May 31, 2003 | 02:15 PM
hondaexrider's Avatar
Default how to adjust rider weight on works shocks?
Hey! I ride a honda 250ex and just bought works dual rate shocks without rezzys. They didnt come with instructions how to adjust the rider weight or preload. Does anyone know how to do this? If so, thanks alot. Also if anyone has a manual, could they scan it and send it. Thanks.
Old May 31, 2003 | 06:35 PM
LotusPosition's Avatar
Unless they are have the threaded preload adjustment, you will have to compress the springs, and remove the "c" clip, and move the clip up or down in the notches. The clip is hidden by the spring perch on the adjustment end, and will only be visible/movable when the spring is slightly compressed.
Works generally asks you for rider weight before purchase, thus tailoring the shocks to your personal needs.
Old May 31, 2003 | 08:01 PM
O thanks for your response. I bought the shocks used so they weren't set up for me. They are set for a 150-175 lb rider and i weigh around 130. I have the preload adjuster. Do you loosen the adjuster to soften the shocks? How much should u? I don't have the manual so Im not sure. Thanks again.
Old May 31, 2003 | 08:11 PM
For more preload (heavier rider), turn the adjuster to make the spring "shorter", less preload, make the spring "longer".
Old May 31, 2003 | 08:22 PM
Ok. that will help a lot. Thanks a lot man. Do you think i'll need ressys for normal weekend riding?
Old May 31, 2003 | 08:36 PM
Rezzies are really only needed for long, long extended periods of hard riding, like racing. The rezzies help cool the shock oil, reducing fade. Not needed for the average rider. I have them only because of the deal I got on them, I don't need 'em either. [img]i/expressions/face-icon-small-smile.gif[/img]
Where in Pa do you live/ride?
Old May 31, 2003 | 09:15 PM
I live in Saylorsburg. Pa and usually go riding at Jack Frost, Paragon Trail system, or our local track. What about you? I might get the ressys if I get more involved.
Old Jul 3, 2003 | 12:56 AM
Derrick88's Avatar
So how do you like your new shocks?
Old Jul 3, 2003 | 01:13 PM
They are great! Stock, the 250ex only has 5.9" of travel.........now i got 7.1" of travel. They're well worth the price! also elka makes shocks for the ex but are overpriced. Go with the works if u decide on getting aftermarket shocks.
Old Jul 3, 2003 | 11:27 PM
Derrick88's Avatar
Do they have any type of compression or rebound adjustment?
Derrick[img]i/expressions/face-icon-small-smile.gif[/img]
