slime???
Old Aug 23, 1999 | 05:50 PM
rgv's Avatar
rgv
does slime really work to seal holes???
I'm getting new tires and am wondering if it's worth putting in.
thanks
Raul
Old Aug 23, 1999 | 09:11 PM
whisky's Avatar
yes i tried it and it works but i put it in after the hole was in the tire
99 500 scrambler with hotseat pipe and clutch dg bumper soon to have pistons and air box mod 93 yamaha t-wolve with a broken taillight soon to be fixed tailight is now fixed now need to fix headlight
Old Aug 24, 1999 | 12:47 PM
hot_shoe_cv's Avatar
Raul, as you know, Slime is a preventative product like tooth paste. One doesn't use tooth paste after he has cavities, but before. I put a gallon of sealant (don't recall which one) in the tires on my King Quad when I bought it new & ran it all over Az in search & rescue operations over cactus, rocks, broken logs, sharp glass, you name it, & wore out the tires without ever having a flat.
I guess it's like the tooth paste thing..who knows if it works? I do know that when I replaced those tires there were all sorts of little objects sticking thru inside the tires.If you do use it be sure to use a quart per tire & operate the bike at a moderate speed for about a mile to circulate the sealant immediately after adding it.
Cal, the Az Hard Packer
join the Blue Ribbon Coalition online at www.sharetrails.org
Old Aug 24, 1999 | 01:16 PM
jim's Avatar
jim
The stuff works great. I let the tire sit w/ the hole pointing up & the tire went flat because no Slime could get to it. So I pumped it back up & pointed the hole down, I could hear the slime gurgling in the hole & the next day, presto, the hole was filled. That was a year ago & it hasn't gone flat since.
Jim
Old Aug 24, 1999 | 02:08 PM
boomer's Avatar
Stuff works great. Havent had a flat since I put the stuff in..stock Dunlops too!! Its also helps in balancing the tires.
Boomer '99 Wolverine
Old Aug 25, 1999 | 12:28 AM
rgv's Avatar
rgv
thanks for the replies guys!
I'll definitely put it in when I install the tires. Its nice to see a miracle product out there that actaully works.
Raul
Old Sep 2, 1999 | 10:47 AM
Harold's Avatar
i just put some slime in a garden tailer that had holes in the tires and had been sitting on the ground for two years and had dry rot cracks also, guess what no more leaks, this stuff really works!!!!
Old Sep 11, 1999 | 09:31 PM
jnelson's Avatar
Where do you get slime in bulk containers?
Thanks
Old Sep 11, 1999 | 10:37 PM
Shane West's Avatar
NAPA sells a product called "Flat-Proof" in gallon size bottles. Same liquid goop. Worked for me!!
Shane
'97 Honda 300 4X - Vamped, Locked, & Lifted
Old Sep 13, 1999 | 10:51 AM
Harold's Avatar
To buy in bulk try Northern.
