V Pattern Paddles
When mounting a V pattern paddle (sand shark, sand skate, etc..), does the longer side of the V go toward the inside or outside of the wheel? Does it matter? Does having it one way vs the other make a difference when turning?
However, you can mount them with the correct directional allignment and still have the longer paddle in or out depending on which side you bolt the wheel to the hub. I'd like to find out what difference it makes in handling. Anyone?
The short part of the "V" paddle is supposed to be mounted on the inside on both wheels with the longer portion of the paddle on the outside. As for effect/ride if mounted the opposite way, It will work, but I have always heard that the above way is correct for optimum turning/sliding.
Rude Dog
Rude Dog
Quadzilla Heritage
Sep 25, 2015 01:39 PM
blueandy88
Aug 30, 2015 08:26 PM
