400EX A-arms on a 300EX
Has anyone have any experience with installing 400EX a-arms on a 300EX?
I have the following questions:
-I noticed that the only measurment not the same is the difference between the upper left and right a-arms bracket on the frame is around 3/4" shorter on the 300EX, which should make the top of the wheels lean in considerably, any problems with that?
-Do you still use the 300EX spindles?
-Is there any binding?
-Is this a complete bolt-on modification, or is there any grinding or welding besides the shock bracket kits?
-Is there anyone with some up and close pictures of this conversion out there?
