wetlands tires
Old Feb 22, 2005 | 10:30 AM
captainskodiak's Avatar
Default wetlands tires
Hello All, I am a new member, but have been doing extensive research on tires for my 05 Kodiak on the forum. After much time and energy spent where and what to buy, I decided on the new Wetlands tires. It seems to incoporate all the features that I wanted: radial construction, more agressive than my stock tires, extended tread life( we will see), and my spending budget of under $300 for a set. I ordered them yesterday from motorcycle-superstore.com, and should be delivered in less than a week. Thanks for all your help, and I will be giving updates on the performance of my new treads.
Old Feb 22, 2005 | 08:56 PM
MikeM's Avatar
Did you get the 25" or 26"?
Fedex has my 26s, going to get them tomorrow!
Old Feb 23, 2005 | 12:05 AM
I decided to go with the 25" tires. I was a little concerned about losing hp. May have not seen any difference but I wanted to stay under $300, including the shipping cost, it totaled $299.96. Has anyone out there ran the new wetlands, and how have they performed? I was not even sure how long they have been out, just saw them about a week ago, and looked about like the perfect tire for my riding style.
Old Feb 26, 2005 | 01:23 AM
elkbow's Avatar
The Wetlands are the same as the Polaris PXT's which are on the 2005 Polaris machines. You'll love them. I have aftermarket tires/wheels also, but those PXTs ride so nice, are a radial and 6 ply....tough, smooth with great all-around tread. They work pretty good in the mud too...
dave
Old Feb 26, 2005 | 01:56 AM
Thanks elkbow thats what I wanted to hear. Was a little nervous about buying a tire I had not been able try out, like the 589's and mudlites, which I have used, they are both a great tire but wanted a radial without scraficing alot of mud performance.
Old Feb 26, 2005 | 10:09 AM
elkbow's Avatar
You will definitely be happy with the Wetlands. For what you described, they will work great for you. I keep swapping my 27" Mud Lites and 589's off and putting the 26" Wetlands (PXTs) back on for the nice ride....and they perform....
dave
Old Feb 26, 2005 | 02:52 PM
MikeM's Avatar
Only took a short ride down to the river and back, so I can't fully evaluate them, but 1st impression is good. First thing I noticed is that it steers easier. Counterintuitive to me because it has a larger contact patch, but it was noticeable. The other thing was that they tracked straighter. Less steering input to stay where I pointed it (4" fresh light powder on frozen base with ice spots). The quad also slides less (almost none) on side hills. Hope to get a good ride in Sunday. Nice tire so far. Glad I went with the 26” because they look better than those ballons I had before and I have ľ” more ground clearance with 7psi.
Old Feb 26, 2005 | 09:44 PM
Sounds like they are going to be a perfect fit. Does the sidewall recommend 7 psi, I have only been running about 4-5 psi in my Maxxis OEs.
Old Feb 27, 2005 | 10:16 AM
MikeM's Avatar
Yes, the rated load is at 7psi, only reference I could find on the tire. Figured it would be a good place to start. I ran 5 in my OEMs too.
Old Feb 27, 2005 | 11:22 AM
elkbow's Avatar
The max pressure is 7 psi, I run them at 6 psi and I run my mud lites and 589's at 5.5 psi.
