Vision 160 specs
- Vision 160 wheels for Sportsman 700, 4/156 bolt pattern.
12x7 front 4 + 3 offset, 13 lbs
------12" diameter/ 7" width at bead seats.
------7 3/4" outside width total to outer most edges.
------4" offset from mounting face to inner wheel edge. (at suspension)
------3 5/8" offset from mounting face to outer wheel edge.
------2 1/2" offset from outside B.C. face to outer wheel edge.
12x8 rear 4 + 4 offset, 14 lbs
------12" diameter/ 8" width at bead seats.
------8 3/4" outside width total to outer most edges.
------4 3/4" offset from mounting face to outer wheel edge.
------3 5/8" offset from outside B.C. face to outer wheel edge.
-The Vision 160 is HD with a capitol H-D (375 lb max load ea.) and have a machined, clear coated finish. Very good quality.
-Included are caps (chrome) and specialized tapered lug nuts.
I got the Visions from Matt at ATV Outfitters (after doing some research).
Shipping and handling was fast, I called him on Friday around noon, and they were here on Tuesday afternoon!
Thanks Matt!
I hope this info helps someone to make an educated decision on their future wheel purchase.
Jim
Thanks Matt!
Jim
