tires, and wheels for sp700
Old Mar 23, 2005 | 12:30 PM
M40A3nut762's Avatar
Default tires, and wheels for sp700
i have a blue carb model 700 04 model, and i want to get new wheels and tires for it. im sold on maxxis 4X4 5 spoke wheels, and mudzilla tires, my questions... which bolt pattern, or whatnot do i need for my 4 wheeler?? and can i get the 27" tires on it without a lift??? how much will it affect my power??
thanks, cory
Old Mar 23, 2005 | 01:48 PM
jimmypsp700's Avatar
You will need front spring spacers with anything over 26".
The Zillas are heavy and you will notice a diff but the 700 has the power to churn em in mud.
I dont think the new 4x4 comes in a polaris 4/156 bolt pattern yet and the rokstar dont offer caps yet for the polaris.
Your choicses are the ITP C-series, Vision, and Maxxis Maxlite 8 spoke and 4 spoke.
You can go on ebay abnd ask the sellers questuons but they will know what to send you if you order .
Check out ATV Outfitters, Matt can help, or Lester Tire and ATV.
Jim
ps. Silverbullet and maybe Elkbow will chime in shortly.
Old Mar 23, 2005 | 02:43 PM
thanks jim, on maxxis.com, they list them available with a 4/156, which fits the polaris. still tyring to get ideas on the tires. im going to to ahead, and order a lift kit, so do you think i should just go for 28" tires instead??
thanks, cory
Old Mar 23, 2005 | 07:47 PM
four4fish's Avatar
dont buy 1 make your own out of hockey pucks . i think their better and alot cheeper and super easy to make. want direction pm me.
Old Mar 23, 2005 | 11:12 PM
PolarisTheOnlyWayOut's Avatar
make sure the rims you purchased are offset or they will rub up against your tie rods...if they arn't u will be chukin out 110 bucks for a pair of spacers...
Old Mar 24, 2005 | 06:15 AM
You will need 2"spacer.
Alum is better Silverbullet makes them.
Jim
Old Mar 24, 2005 | 10:14 PM
silverbullet2005's Avatar
M40A3nut762, even if you install 2" strut spring spacers you won't clear 28" tires without rubbing issues. if you want to install 28's you would have to get a 3" suspension lift like from berts dirt works. the catch with the 3" lift is that you have to also install gorrilla axles due to the severe angles.
take a look at my gallery, I installed 27" ITP Mudlites on ITP type 6 wheels and the spacers I made which are 2" aluminum and I have no rubbing issues. I am not selling the spacers any longer so you will either have to make your own or buy them online. I would stay away from hockey pucks if it were my rig but that is just my 2 cents right? If you purchase a lift or spacer kit take into consideration that the highlifter kit is like a body lift and the strut spring spacers are actually lifting the suspension.
just out of curiousity why do you want the Mudzillas over like the Mudlites or 589's or even others like the bearclaws etc? I recommend checking out lesteratv.com for wheels and tires. I got mine from them, you can go to their website but prices seem to be a bit higher online. Call Melanie at lesteratv.com and tell her Dave Krueger sent you her way and she will help you out.
Old Mar 25, 2005 | 09:10 AM
thanks alot silverbullet, and others, i want the zilla's, becuase i think they are th ebest mud tire there is, and they arent bad on hard pack. as of now, im either going with 26", or 27".
cory
Old Mar 25, 2005 | 11:36 AM
four4fish's Avatar
are you guys just putting spacer under the springs to do the lift i thought if you did that it would just stiffen up the suspension and limit the travel causing a much harder ride i thought you also had to add the same amont of lift under the strut. i run 28" 589 on my 02 with a 1"homemade lift out of hockey pucks . i found you can run alot bigger tire without a lift . the tires dont normally rub on the top of the fender but at the floor boards, most case you can loosen the floor board up pry them back and retighten or on 28 s redrill them . my 02
Old Mar 25, 2005 | 01:46 PM
four4fish's Avatar
looking for real nice aggressive tires cheap check nebraska tire for tsl asx's real cheap 1st quality not blems
