Tire/Rim Sizes---I'm Confused
Old Aug 9, 2015 | 10:31 PM
thaiboy's Avatar
Retired Warrior
Default Tire size and rim size
I have an ATV which has 19 x 7.0 - 8 tires (Rim width is 6 inches) I want to install 18 x 8.5 - 8 tires on these rims. Will this work?
Old Aug 10, 2015 | 01:36 AM
greg74's Avatar
People put wider tires all the time on stock wheels on full-size vehicles. I would guess that probably up to 2" wider would be ok on stock wheels but that's pushing it. It gets to the point that with stock wheels, clearance might be an issue on the back side of the tire, especially on the front. You might not be able to turn the bars fully before the tires start to rub. That's why most aftermarket wheels are offset. It makes the quad wider but that's not always a bad thing. Putting on larger tires raises the center of gravity so making the quad a few inches wider makes it more stable. The only drawback is that tight trails become really tight then. And tires might stick out past the fenders so you'll sling more mud on yourself than with stock tires.
akguy31
Aug 31, 2019 04:34 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Pissed off
Sep 21, 2015 02:33 PM
Halffast17
Sep 11, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
