More questions
I have a 2005 suzuki ozark and I am getting alot of valve chatter at high rpm and when I am accelerating up hill. I had the valves adjusted but it still does it, anyone have any suggestions?
Also ozarks have a carb drain screw and a hose that runs behind the motor to drain the carb and for some reason it leaks gas out that tube all the time. I have tightened the drain screw as tight as possible but it still drips out that hose when the atv is running. Any help on this would also be appreciated.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
