what size tires should i get on a 06 yamaha wolverine 350?
Since they come with 23" tires, you don't have too many choices. Why don't you like the stockers? I hear nothing but good things about them. If you want a more mud oriented tire then you might have to go up to 25", but on a little 350 2wd with no low range that might be a bit much unless you put in a clutch kit. Otherwise if you want a sportier ride and don't mind losing some ground clearance, maybe you could get away with 22" in back and 22"/23" in front. But otherwise if you are just trail-riding then the stockers should be fine.
-Krait
-Krait
toonces
Oct 16, 2019 12:11 PM
Jul 7, 2015 11:00 PM
