Anyone's nuts ever fall off?
Oh god,I aint gonna do it,[but if u feel there torqued right dont see where locktite would hurt,they make 2 different types,red and blue one is made so they,ll never come off one used for such as that or scopes on gun what have you.red and blue i think if i remember right!Paul
When you install mew ITP wheels you will check and retighten if necessary the lug nuts after some riding. I put 15 miles on mine and even though they were plenty tight to the correct 50 ft/lb torque as required they were starting to become loose and I needed to re tighten them. I would check them occasionally until they take a set.
Re loctite the blue is med strength and red is hi that would need heat or special tools to remove.
Not that you should need it, but the blue is the one that you could use.
well, I fixed the problem, they just need to settle in. I tightened them, and then did some riding and retightened them. I checked periodicly after that and I think their on for good now
