cdi
the moose module only messes with the low end timing. the cdi changes the timing curves from the bottom to the top end.
for my riding needs i chose the moose module, since i usually only mess around in swamps and mudholes. it was deffinilty a noticable kick in the *** in the low end powerwise
The Dynatek is WAY better. If you get the moose, you will only want the Dynatek within a couple weeks. The dynatek gives a power boost from all the way through the power band. The moose only helps at take off
