16T sproket banshee
Old Jan 25, 2001 | 04:14 PM
tomtuna's Avatar
Do any of you have this on your bike?
will 2 teeth really make a diffrence
on top end?
Old Jan 29, 2001 | 04:26 AM
AdrenalinFreak's Avatar
I figured this out a while ago, and my memory sometimes fails me, but, on a stock geared banshee with 20 inch tires on the back you can expect around a %10 increase\decrease in 6th gear for every tooth that you inc\dec on your front sprocket.. My math might be a little off, and its not always 10% as the rpm chart becomes a curve (1 tooth would be 10% 2 would be 19% ect.) Also to note, it takes 3 teeth on the rear sprocket to make the same change as 1 tooth on the front. You will also lose considerable low end power if you change your gearing to a 16:41
Why would you want to put a 16t sprocket on anyways? The only application I can see for going anything bigger than a 15t is for pure top end salt flat type drag racing!
Old Jan 30, 2001 | 08:49 AM
seven's Avatar
A 16 tooth front sprocket wont fit on a banshee the biggest you can go is 15 without messing around with the case
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
