Dirty Air Filter
Old Nov 10, 2008 | 09:29 PM
bsan1827's Avatar
Default Dirty Air Filter
What causes the machine to run hotter when the air filter is clogged? And can this cause overheating?
Old Nov 11, 2008 | 08:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
A clogged up air filter will cut down on the amount of air, and that should make your mixture rich, not lean. Usually, one associates running hot with a lean condition, so that doesn't fit a pattern. Might be some other problem????
Old Nov 11, 2008 | 11:33 AM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Ditto here!! Dirty air filter richens you up, and therefore shouldn't heat it up.
Old Nov 11, 2008 | 12:27 PM
Red Rider
Water cooled??? If so, maybe you have a cooling system problem???
95wolv
Sep 27, 2024 12:00 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
