330 Trailboss Silent Chain
Old Jul 1, 2013 | 01:50 PM
dwanchena's Avatar
Default 330 Trailboss Silent Chain
Im investigating the grinding noise on my trailboss. All external parts are fine (drive chain and sprockets). I splint the gear box and found everything in acceptable condition. (There were shavings on the drain plug) What I did find is excessive slack in the silent chain. Is it possible for that chain to stretch that much? Clearly it was rubbing on the bottom of the gear box. It appears it is about 1/2 link too long now. Thanks for any input!
Old Jul 1, 2013 | 02:02 PM
Replace the silent chain and the two gear case seals.You'll see a difference on the new one as far as slack.This is the most common wear item in chain driven gear cases. Also check that the gear lugs and teeth are ok and the bearings turn smooth without any roughness.http://www.cyclepartswarehouse.com/f...2003&fveh=5623
Old Jul 1, 2013 | 03:45 PM
dwanchena's Avatar
That's route I was going to take but just wanted confirm with someone else. Thanks for the help
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
