1991 polaris trailboss 4x4 issue
Old Feb 14, 2016 | 02:11 PM
As long as you can stop the front tires from spinning while up in the air when you kick the awd off,sounds like it's working ok. Post or tree will usually work fine. Better if the rear tires are in gravel or loose ground and able to slip to enable the fronts to kick in,but you can usually find someplace you can test it out.
Old May 7, 2016 | 08:38 AM
Gusgusa1's Avatar
If you can stop the front from turning at all especially with minimal effort your awd isn't engaged. They will rotate with the axle rotation but will not kick into awd unless the armature is energized. I had a shorted wire in on the strut where it was held by a zip tie. Melted the wires together grounding both wires. Result no lock up. Fixed the wires and I now have awd.
Old May 7, 2016 | 08:39 AM
Gusgusa1's Avatar
Mines a Polaris xplorer 400
joeysaen
Nov 26, 2015 11:13 PM
Nov 25, 2015 09:09 AM
1ArmBandit
10
Nov 20, 2015 03:36 PM
