Bear Claws
Old May 3, 2003 | 01:05 PM
WeAREsane's Avatar
Default Bear Claws
How does this tire performe in the sand? Anyone had experience? thanks
Old May 4, 2003 | 02:15 AM
1Bullmoose's Avatar
Default Bear Claws
I have a set of Bearclaws on a 450 Foreman. They are a big improvement over stock tires and work well in soft conditions like sand, mud, and snow yet still ride fairly smooth on hardpack. My sand riding has been limited to a few beaches and sandy pine areas, not desert-like sand dunes. After about 500 miles they hardly show any wear. My only complaint is that the Bearclaws seem to have a very flat tread profile compared to some other brands. This may help in the soft stuff, but it greatly increases steering effort. Hope this helps.
Old May 4, 2003 | 05:09 PM
BuckinHO's Avatar
Default Bear Claws
Excellent traction everywhere But a bit hard, and should only be used on shaft drives other wise they will stretch chains fast and destroy bearings.
Old May 20, 2003 | 11:23 PM
CatRider's Avatar
Default Bear Claws
1Bullmoose, what size Bear Claws are you running and what PSI are you running in them. I am looking for a flat tread profile and thought the Bear Claws were more rounded. Also, how deep is the tread on your tires? Thanks for any info.
Old Jun 1, 2003 | 11:07 AM
skidder's Avatar
Default Bear Claws
Greetings fellow mud beings
WeAresane from my experience Bearclaws dig until they hit something solid and then they launch you. With sand I think something with a more of a paddle tread would be the answer. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 6, 2003 | 02:12 PM
HighRider's Avatar
Default Bear Claws
So how are BearClaws for "general" riding?
It's getting to be tire-time on my Foreman 450 ES, and I'm hearing that BearClaws have a softer ride, better traction, tougher & longer wearing tread, and better light-to-medium-mud performance than the stock Dunlops.
I'm thinking of going up a size (from stock 25" to new 26) for lower top-end revs (for top gear riding out to the play-zones).
The Foreman isn't exactly light-steering as is, though mine steers lighter in 4WD than in 2WD, at least on winding dirt roads.
Heavier steering? Might be a problem!
Any experience with BearClaws for "regular" use (sand & dirt roads, rocky climbs, slickrock creek crossings) ??
Old Jun 6, 2003 | 07:59 PM
CatRider's Avatar
Default Bear Claws
Highrider, my AC is full time 4X4 and steer about the same or a little easier than my friends full time 450ES. I put 26X9X12 Bear Claws on the front and 26X9.5X12 Radial Outlaws on the back. I love it. The front steers easier than the stock tires and the outlaws have much better traction. I only have 100 miles on them so far, but the ride has been excellent.
Old Jun 6, 2003 | 10:20 PM
01redrecon's Avatar
Default Bear Claws
The bearclaws do alright in compacted sand but in really loose stuff they tend to dig down to much, or atleast this is from I have found out. I think bearclaws are one of the best all purpose tires. They have great wear and I find they handle just as good as stock (as long as their aired up so that the side lugs don't dig in) but with a little rougher ride. The only downfall about them is that they dont clean out well in thick mud. My 22x12 bearclaws had a little oveer 1/2' deep lug and the same for the 27x10 but the 27x12 have close to an inch deep lug.
Old Jun 11, 2003 | 05:18 PM
trailburner's Avatar
Default Bear Claws
I mostly stay in the muddy and rocky conditions, but had the chance to go to Jericho Dunes (Little Sahara) in central utah and I let a enough air out to get me to 3 lbs in each tire and they handle really well. The first time I went, I had about 6lbs and there was deffinately a difference. They kept on digging in but let have the air out and hold on. I highly recomend these tires for all around even in the soft sand for utilities.
Old Jun 17, 2003 | 10:43 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Default Bear Claws
I have had Bearclaws and I think they were fair. I would look at the Mudrunner or the new ITP Mud Lite before the Bearclaw.
