Dunes and Dune Machines Discussion on dunes and dune machines.
Which Raptor paddles?
Old Aug 24, 2004 | 11:48 PM
iweb's Avatar
Default Which Raptor paddles?
Yes I did search but I am now more confused than before on which paddles to get. 03 Raptor jetted,snorkel taken off, and thingie taken out of muffler. I just switched from sandrail to quad and I ride in Amargosa and Dumont. I like to dune mostly and ride side hills and might run comp once. I was using Trakkers and they suck, I would get stuck on flat ground and my friends yfz 450 smoked me up comp twice and he was running Geckos. Someone said the haulers and extremes are too much paddle for the Raptor, it would dig in too much and just do wheelies. I liked the one comment made about getting an 8" rim but I really need help here so I can order some. I was told to get ITP 190 but in Rocky Mtn it shows a TP9 and an upgrade to 190 so whats that all about? Thanks.
Old Aug 25, 2004 | 02:12 AM
DC504's Avatar
first you gotta figure out whether you want a strait or v paddle. straits will give you maximum hookup for drags and hillclimbs, but will not turn great and will not slide as good. v paddles will still give a lot of hookup, though not as much as straits, but they will turn good and silde good.
Old Aug 25, 2004 | 02:33 AM
bonebreakers's Avatar
if u ride on sand alot try 4snows i think better than paddles and tire baloonsontop end more top speed and hooks up awesome cheap tire too ull like em
Old Aug 25, 2004 | 10:31 PM
iweb's Avatar
Ok I got the rears figured out, now what size for the fronts? I am going with Dune Runner or Mohawk, any input?
Old Aug 25, 2004 | 11:28 PM
FireFly's Avatar
I have 3 raptors running haulers 20x10x10. When you order from rocky mtn, their 10inch wheel is wider if you use douglas wheels. That make the tire flatter you get better bite, but it will slide when you turn it. They have different thickness on their wheels. I would suggest at least .160's or if you jump alot go with .190.
bmxatv10
Oct 14, 2022 06:23 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
